Header gasket
Old Nov 9, 2012 | 11:32 AM
s2000maniac's Avatar
Default Header gasket
The header gasket only goes In one way right? I noticed some exhaust leak around the header where it bolts to the engine block.I'm thinking I'm might not have made the bolts tight enough.
Old Nov 9, 2012 | 12:05 PM
MM3Kwolik's Avatar
Yep, only goes in 1 way. It may be able to be flipped, but that won't change how well it seals. Either you have it improperly torqued, or one of your surfaces isn't perfectly flat anymore.
Old Nov 9, 2012 | 01:05 PM
okay thanks, do you mean the surfaces on the gasket or the header? I did buy a brand new gasket when i installed the header.
Old Nov 9, 2012 | 02:44 PM
MM3Kwolik's Avatar
The surfaces of the head and header. If the header was previously installed improperly it's possible that it warped. You could check it with a straightedge if retorquing it doesn't work.
Old Nov 9, 2012 | 04:44 PM
okay thanks
Old Nov 9, 2012 | 05:49 PM
Nutterbutter's Avatar
If everything is flat, try copper or red rtv and tighten from the center out.
Old Nov 9, 2012 | 08:34 PM
realblag's Avatar
What header do you have? If its a cheap one, it is very possible it was not straight and true when it was made.
Old Nov 9, 2012 | 10:15 PM
It's a mugen header.
I'll loosen the bolts and start tighten them down from center. Hopefully that does the trick.
Old Nov 10, 2012 | 03:54 PM
This the header gasket pic
midnightmethane
Jan 12, 2011 05:28 AM
marknconnie
Jun 27, 2010 06:48 PM
CrAzYNeSs
Apr 21, 2005 04:45 PM
S2K_408
Mar 21, 2005 08:33 PM
chungtaho0918
Jul 21, 2002 06:57 PM
