Header latch for top
Old Dec 16, 2007 | 02:53 PM
fredman's Avatar
Default Header latch for top
My header latch on the drivers side of top needs adjustment, it isn't pulling the top tight,
and getting wind noise. Can't figure out how to adjust so it pulls down tighter. [FONT=Times]
Old Dec 17, 2007 | 04:12 AM
z4k's Avatar
z4k
I have never attempted this but if the Catch that is on the windsheild has ability to slide forward it would make it tighter. I need to look into this as well. I also hear Hard Top Catches are better? Someone want to verify?
Old Dec 17, 2007 | 06:16 AM
BEASTMODE's Avatar
Hardtop strikers should make for a tighter seal.
Old Dec 17, 2007 | 07:29 AM
1FastS2k's Avatar
If you want a quick/temp fix, go to WalMart or Petco and get some clear plastic fish tank tubing and slide it over the hook part of the latch. It should help it latch tighter.
Old Dec 17, 2007 | 05:01 PM
NVMY4N's Avatar
Check the DIY/FAQ for the "hardtop striker" install.
that may not be the exact title.....and it could be under like "soft top fix" just look around you'll find it.
Check your strikers, to see if a groove has been worn.....this is your tell tell sign to swap for HT Strikers, and you can get them through Hardtop Guy for a pretty good price.
Old Dec 17, 2007 | 06:50 PM
street_ruler's Avatar
why are the hard top strikers so much better?
side note, i ahve the factory hard top
Old Dec 17, 2007 | 07:39 PM
NVMY4N's Avatar
The first MY's strikers were a softer metal. the HT strikers (and teh newer cars) are the newer metal.
Jun 11, 2014 06:18 PM
trustafox
Apr 23, 2012 10:25 PM
s2ktimmy
Aug 17, 2008 06:21 PM
smirfs2k05
May 11, 2007 07:41 AM
NAP1
Oct 11, 2004 10:57 AM
