Header removal issue. Stripped nuts
Old Jun 30, 2015 | 12:36 PM
Soviet's Avatar
Default Header removal issue. Stripped nuts
In the process of dropping my trans I began to remove my header and stripped two (the lower ones) of the seven nuts that attach the header to the studs on the head.
I read a DIY guides and there were no special instructions for taking off the nuts. I can't seem to get a socket on them at the right angle since the header pipes seem to get in the way. I have attacked it with a 1/2" ratchet with deep sockets/short sockets and a 3/8" ratchet with sockets. I even tried to reach them from below with a wrench but I wasn't able to get enough torque to break them loose.
Now they are stripped.
I have two questions.
What is the best way to remove these?
What should I do now that these nuts are stripped?
- I thought about purchasing a dremel but I'm not even sure if the attachments will reach the nut.
pics for reference.
Old Jun 30, 2015 | 01:09 PM
V6 Donut's Avatar
id hammer over a slightly smaller standard socket over the rounded nut with an extra long cheater bar and use as little heavy impact jerking as possible.
Old Jun 30, 2015 | 01:50 PM
noodels's Avatar
Could get a drift or blunt chisel on the one visible in picture
also put the other nuts on to pull tight
Old Jun 30, 2015 | 03:06 PM
Slowcrash_101's Avatar
Grip tite sockets. http://www.amazon.com/Grip-Tite-Supe.../dp/B003M68V6E
I think they have them at the auto parts store. They usually work.
Old Jun 30, 2015 | 03:19 PM
Soviet's Avatar
The problem is that there is absolutely not space. Less than a two finger gap.
Old Jun 30, 2015 | 03:24 PM
Soviet's Avatar
WOW. That looks amazing. I think that, coupled with a swivel socket set may be what I'm looking for.
I not only need something for the stripped nut but also something that can handle the angle so I don't f@#k it up again.
Old Jun 30, 2015 | 04:19 PM
99SH's Avatar
Swivel sockets have always worked for me. There should be plenty of room to put a wrench on the nut to break it loose.
Old Jun 30, 2015 | 05:26 PM
windhund116's Avatar
Easier to get to it, from the bottom?
Old Jun 30, 2015 | 05:32 PM
Soviet's Avatar
Do you mean from below? From above there is definitely no room.
Old Jun 30, 2015 | 06:02 PM
dagle's Avatar
The one in the last picture looks like you could reach it with a wrench from underneath the 4th runner. If not, see if a long extension will do the trick. In both cases, attach a pipe for more leverage if need be. The header nuts/studs were kind of designed so that they could be taken out with standardized sockets by most mechanics. The header you have on the other hand, I'm not so sure.
