Headlamp Restoration Success
Old Oct 21, 2025 | 02:32 PM
B serious's Avatar
Originally Posted by The King
Thanks for clarifying that. Is there a particular type of clear coat to go for?
Originally Posted by Catticus
I used wet&dry from 1,000 to 10,000 grit, followed by two coats of E-Tech Restored Headlight Clear Coat. It's been 2 weeks now, and the lights still look as they do in the final picture.
Any 2K clear will work fine, however.
Any 1K clear will not work long term.
Old Oct 21, 2025 | 03:14 PM
The King's Avatar
2K it is then. Thanks!
Old Oct 22, 2025 | 03:37 AM
Kyle's Avatar
Beautiful job, looks fantastic! With these cars aging and BNIB becoming discontinued, this seems to be the best course of action and the results can yield damn near like new headlights.
Curious; is there a point to going any finer than 10k grit before clear is applied? I see some people asking, as well as some resto videos I've seen where they go all-out with a DA buffer and cut & polish before applying clear and polishing again. I see you didn't and they still look amazing.
Realistically, wouldn't the clear coat fill all of the scratches and imperfections in, as well as having something to adhere to on a non-polished surface? I'd imagine any polishing should be done after a few days of applying clear for the best results. I see no need to do so beforehand, but I am farrrrr from an expert when it comes to this stuff.
About how long did this process take you? I have a set I need to restore, and I'm most likely just going to remove them from the car and do them by hand. I'd imagine I can just spend the day at my leisure sanding them down grit by grit and then get some clear on by the end of the day. I also heard that 2k clear doesn't play well with polycarbonate lenses, but that's the point of specific 2k just for headlights. I'd definitely go with an epoxy 2k clear over 1k. And then either UV-resistant PPF or ceramic coating applied to the lenses after polishing the clear.
I'd definitely do this over buying new headlights or trying to swap lenses with eBay lights. The only time I'd consider swapping lenses is if they started reproducing just the lens, a venture which has never panned out for us. Again, nice work!
Old Oct 27, 2025 | 01:28 AM
davidc1's Avatar
Originally Posted by cosmomiller
PPF Film is a borderline permanent haze preventer. I used Expel a decade ago and it has been flawless. If you are careful with your sanding and tape off the lenses well, you can refinish without removing the lights.
What do you mean "borderline"? (I've used PPF on about 6 cars over the last 20yrs..not one has hazed over).
Old Oct 27, 2025 | 01:29 AM
davidc1's Avatar
Looks great, OP!
PPF the headlights to protect them.
PPF protects from both issues.
Yep, I don't uderstand why people bother with clear coat.
Old Oct 27, 2025 | 01:30 AM
davidc1's Avatar
Looks great, OP!
Don't bother with clear cote. Use PPF
Old Oct 27, 2025 | 01:32 AM
davidc1's Avatar
I'm guessing you don't realize that the OEM S2k headlight beam pattern and brightness is one of the best ever on any car. Don't swap with eBay junk.
Old Oct 27, 2025 | 02:51 AM
Kyle's Avatar
Huh? Maybe I misspoke. I was referring to stealing the lenses off of new ebay lights and putting them on the OEM.
Old Oct 27, 2025 | 05:01 PM
darcyw's Avatar
I use 3M PPF on my headlights to maintain clarity. its UV stabilized and protects against road debris.
darcy
thetz99
Mar 26, 2008 10:23 AM
jphish
Mar 24, 2006 07:55 AM
S2FiONE
Dec 15, 2005 08:31 PM
TriaXenginE
Jun 15, 2004 09:00 PM
s2k_9000rpm
Jul 26, 2003 05:14 PM
