headlight: Ap1 / ap2 compatibily
Old Apr 17, 2011 | 01:57 AM
Nagata-San74's Avatar
Default headlight: Ap1 / ap2 compatibily
Hi there
I've found a good deal on AP2 headlight, but without ballast
Do my JDM/EDM AP1 ballast fit on them ?
Thanks !
Fab'
Old Apr 17, 2011 | 02:58 AM
Golden Arms's Avatar
AP1 ballasts are slightly larger and wont bolt on directly. You can make it work with custom brackets, but you'll also need to cut the AP2 housing to fit the AP1 ballast wiring through.
Old Apr 17, 2011 | 05:44 AM
suzuka-blue-s2k's Avatar
They do not just fit, you have to mount them pretty ghetto and you have you cut the hell out of the headlight housing. That could easily kill the value of the lights if you do that. Just find some ap2 ballast and ignitors and bolt right up to them and go. Then you can easily sell your ap1 lights with ballast and everything also for more cash.
Old Apr 21, 2011 | 03:14 PM
Kyushin's Avatar
Banned
Try searching Ebay for the ballasts and igniters, I got them all NIB for very good prices. Having the mfgr # helps alot because for some odd reson, honda marks them up alot for the S2000 and you can get them significantly cheaper when badged for another car.
Old Apr 21, 2011 | 05:29 PM
nartnailuj's Avatar
i heard that if you disconnect the wire on the ballast that goes to the headlight, plug it into the headlight, and then connect it back to the ballast works too?? but don't quote me on that. I remember reading that around somewhere i think.
Old Apr 25, 2011 | 01:25 PM
ripper0306's Avatar
Nag, in the DIY section, you can find AP1 to AP2 Headlights conversion with AP1 Ballast (had to cut, etc)
edit :
https://www.s2ki.com/s2000/topic/275...nd-conversion/
demande sur le fofo Francais si t'as des doutes héhé.
J'avais regardé à l'époque aussi, mais maintenant je veux juste des feux US avec le "amber side"
Old Apr 26, 2011 | 08:29 PM
clarenceskli's Avatar
Does it mean other Honda car sharing the same parts for ballast and igniters? Do u know which model?
ALBERTS2K
Feb 4, 2016 02:00 PM
TookayS2K
Feb 17, 2011 03:18 PM
yotslcee
Jun 20, 2010 08:08 AM
henrywu
Sep 10, 2009 04:38 AM
icecreamballer
Aug 3, 2005 12:45 PM
