headlight fuse keeps blowing
I had condensation in my passenger side headlamp and then that headlight stopped working. I had the headlight re-sealed but my headlight still doesn't work. My high beams don't work either. When I try to turn on my headlight, the high beam turns on for a bout 2 seconds then dies, and sometimes the HID light flickers for 2 seconds also. I tried replacing the fuse but it keeps burning out. Does anyone know what the problem is? I want to make sure that its the ballast before I go ahead and buy a new one. Thanks.
Originally Posted by mrfd3s,May 19 2006, 08:18 AM
Is the relay located in the fuse box with the fuse?
HID headlight assemblies are very sensitive to water. the first thing you should do is to remove the bulb and inspect it. Check to see if there is white or greyish dust on the bulb. I've seen bulbs that short out when they go bad causing the fuse to blow. 10 fuses later you've still gotten nowhere except that the light works for only a split second. Try swapping the bulbs from side to side. I know its not as easy as it sounds but the diagnostic process never is. Its better to figure out what it is and fix it rather than throwing parts at it and be wrong.
RedhotS2k5188
Jul 23, 2009 06:34 PM
