Headlights
Old Feb 24, 2005 | 09:50 PM
ikon_vp's Avatar
Default Headlights
if one of your headlights went out..how would you know if it was the ballast or the bulb?
Old Feb 24, 2005 | 10:12 PM
PWRMKR's Avatar
A swap from side to side.
Old Feb 24, 2005 | 11:41 PM
ikon_vp's Avatar
any other way?
Old Feb 25, 2005 | 03:57 AM
Slows2k's Avatar
The bulb swap is the easiest way to find out.
Old Feb 25, 2005 | 07:27 AM
xviper's Avatar
Do you have a crystal ball?
Old Feb 25, 2005 | 09:05 AM
hellothere's Avatar
if that seems too complicated for you, I would suggest you bring it down to your local Honda dealer.
Old Feb 25, 2005 | 09:35 PM
S2KPilot's Avatar
i noticed a color change with my left HID when it was starting to fail. The road in front of me on the left side had an orange tint while it was bright white on the right side. Then the bulb went out completely in only a few miles. A new bulb was tried (as suggested by the Honda Service Manual) and no joy. Next step was a new ballast and everything was back working. I put the original bulb back in and it worked - now have a spare since Honda won't take back any "used" electrical parts.
I would suggest 1st to check the HID fuses by swapping their positions and then swap the suspect bulb to the working side 1st to see if it works with that HID. This method should give you a good idea if your problem is simple (fuse) , the bulb or the ballast .
Hope this saves you from buying needless parts.
jimnasty23
Feb 23, 2011 03:33 PM
ScubaDivin
Feb 4, 2008 11:33 AM
usmclsc
Mar 10, 2004 07:08 AM
Hondafan
Sep 17, 2002 05:45 AM
S2Thizzle
Jul 29, 2002 09:10 AM
