Heat only kind of sort of works after intake install..
I installed my Top Fuel intake, I rerouted the coolant line that goes from the intake manifold to the throttle body into one piece and got rid of all of that metal junk. The hose that I used DID leak but the level of coolant is still good, I tighted up the hose and there have been no more leaks.
Now my heat only works when I'm moving, but does not work while I'm stopped.
The only other thing I did was remove the valve cover and respray it yesterday at the same time.
What could the issue be?
Check your coolant and vacuum lines quickly. You may have swapped one. Some are the exact same size in that area and if you did not remember which one connected where, they may be switched
LongWolf
11-19-2015 06:52 AM
omg_miiiike
04-13-2011 02:03 PM
