Heater valve and coolant question
Old Jul 10, 2016 | 06:35 PM
Mijae007's Avatar
Default Heater valve and coolant question
Hi guys. Quick question. I unplugged the rubber hose on the heater valve to move my ac lines around and some coolant spilled out. Now im afraid i have air in my system since it made hiccup noises as the coolant was spilling out.
Should i be worried? How do i ensure theres no air? Should i bleed my coolant again? Thanks guys
Old Jul 10, 2016 | 11:22 PM
Mijae007's Avatar
I think im okay. I ended up bleeding some fluid out of the front bleeder located next to the fuel rail.
I had the nose of the car slightly elevated, ran the car for 2mins, turned it off, open the bleeder for 15secs or so (bubbles came out), close the bleeder then repeated this process probably 10 times. Also filling the coolant reservoir. Very little bubble was coming out by the 6th or 7th time, mostly smooth stream of coolant.
Heater still blows hot air. Hopefully im good. Somebody chime in if i did something wrong. Thanks!
khangaroo
Aug 5, 2016 07:30 AM
ManOnFire75
Nov 21, 2014 06:42 PM
2001-S2k
Jun 11, 2014 06:22 PM
drhess06259
Oct 23, 2008 07:17 AM
