HELP!
Old Jul 28, 2019 | 07:04 AM
RigsAp1S2K's Avatar
Default HELP!
Picked up a 03’ with 59k miles. The car ran fine for the first day. Previous owner said it had say for a quite some time. So I added some fuel system cleaner and topped off the tank with fresh premium. That’s when my problems started.
car is throwing codes:
p0505 - idle control system malfunction
p0301 - cylinder 1 misfire detected
p0304 - cylinder 4 misfire detected
Driving, the car is very hesitant, severe lack of power, very sputtery.
So far I’ve done:
New Plugs
New Coils
Adjusted Valves
Checked TPS Voltage.
Cyl 1 and 4 seem to be running lean, and much hotter. it’s damn near smoking my plugs.
Any ideas what I should do?
Old Jul 28, 2019 | 07:07 AM
RigsAp1S2K's Avatar
Also, compression test was 242 across all cyl.
Old Jul 28, 2019 | 07:28 AM
s2000maniac's Avatar
Move the coil packs around and see if the mis fire follows. If the same cylinders show mis fire again I’m betting it’s the fuel injectors especially if the car has sat for a while. Change spark plugs too.
Old Jul 28, 2019 | 07:38 AM
RigsAp1S2K's Avatar
Ive already swapped packs and plugs. I’m thinking you’re right about the injectors
Old Jul 28, 2019 | 04:22 PM
Car Analogy's Avatar
Sat for a long time means injectors are gunked up. Fuel turns to varnish if it sits. Very difficult to remove.
Easy to test by removing injector, plug back in and place into cut open water bottle. Watch spray pattern when turn on key.
chicomacattack
Jan 19, 2015 04:17 AM
jdm_101
Dec 13, 2013 11:33 AM
needans2k2
Oct 25, 2012 10:22 AM
NFRs2kevin
Feb 26, 2010 03:24 PM
facets
Jan 22, 2004 08:21 AM
