HELP?!?!
hey s2ki.
heres what happen. i was on my way home from a wedding an hour and a half away from my house. i was following my brothers Evo X. he started speeding doing 100+ so i did the same. when i shifted back into neutral to coast back to 65 my clutch pedal went dead. i gave it a few pumps and felt some pressure come back into it. once i got her into neutral i couldnt shift back into any of the gears. i pulled over and turn off the car and tried the gears. it worked fine. once i started the car and try to shift it into 1st it wouldnt let me. it was like this with all of the gears.
whats the cause of this?
i have a 01 Silverstone with roughly 110k miles on it. i thought it was the clutch master cylinder and the slave cylinder so i replaced them both. still doesnt go into gear. any suggestions?
mods on the car are: megan exhaust, built bottom end, competitions stage 2 clutch kit.
i have an 04 ap2. When i get on it, my clutch seems to loose some pressure. Its gets pretty soft but after a pump or two its back to normal. Its never been to the point where i cant get the car into gear.
Also, when i had my prelude back in the day, i couldnt get my car into gear either, only when the car was off like yours. Problem was the pressure plate
davidh99
Oct 21, 2010 07:08 PM
