Help! ABS light after spring install
Old Apr 13, 2004 | 08:30 AM
KaMxiKaZe's Avatar
Default Help! ABS light after spring install
Just like the topic states. I installed a set of KG/mm supersport springs yesterday. Everything went well except when I started the car up the ABS light stayed on. I tested the brakes out, they are working fine except ABS is disabled. What could I have done to cause this and how can I make sure its not a false alarm or something?
thanks in advance!
Old Apr 13, 2004 | 08:32 AM
vodalus's Avatar
You could have damaged an ABS sensor.. Follow the procedure in the Helms manual to check them.
Old Apr 13, 2004 | 08:34 AM
Hockey's Avatar
Sounds like you may have dislodged on of the ABS lines when you were under there. Gonna have to get back under and do a visual inspection.
Anyone able to post a layout so he looks for the correct lines?
Old Apr 13, 2004 | 09:27 AM
xviper's Avatar
The ABS sensor line at each wheel is pretty obvious. They look like an electrical wire bundle. Just start at the ABS pick up by the wheel and trace it back until it disappears into the body.
Old Apr 13, 2004 | 10:32 AM
KaMxiKaZe's Avatar
Thanks for all the input, ill have to check everything out tonite.
Old Apr 13, 2004 | 02:41 PM
KaMxiKaZe's Avatar
Hmmm. So I checked all the wires (I think I was looking at the right ones) and everything seemed to be ok. Im not really sure what Im looking for but the wires seemed in tact and working fine. Not really sure what else to look for, not to mention the fact that this sorta thing seems to be outta my league. Any other suggestions before i just take it to the dealer?
Old Apr 13, 2004 | 02:45 PM
xviper's Avatar
You may have stretched one of the ABS wires and it's broken inside OR, you could have impacted the ABS sensor so that it is no longer aligned correctedly with the toothed wheel.
Old Apr 13, 2004 | 04:11 PM
KaMxiKaZe's Avatar
Thanks for all the help, I think im just going to get the dealer to look at it while I get my alignment done. Thanks again!
FromaDB2toanAP1
May 9, 2015 12:02 AM
lilbizzyazn
Jul 15, 2010 07:54 AM
Hyper_R
Jun 23, 2008 10:57 PM
Luke530
Aug 17, 2006 12:20 PM
ImportSport
Apr 7, 2004 11:12 AM
