abs light after installing coilover
Old Nov 1, 2005 | 08:17 PM
lilbizzyazn's Avatar
Default abs light after installing coilover
i installed my coilover and after put everything back, turn on key on and ABS light was on..so can anyone tell me what might be the problem is? wires is not loose
Old Nov 2, 2005 | 01:21 AM
Siepel's Avatar
Lamp is supposed to come on at key-on.
Did you start AND drive the car and did the lamp stay on? In that case, high probability that there is an electrical disconnection.
Siepel
Old Nov 6, 2005 | 03:15 AM
volkrays's Avatar
Unhappy
check ABS sensors wiring on the front of your car. when changing shock/springs on the front, the upper A arm must be removed, i'm assuming u did this to remove the OEM shock and spring.
When the upper A arm is removed the suspension is left dangling by the ABS sensor wire, a 30-40 lb brake/suspension can easily damage or pull on the wire and damage it internally.
Check for continunity and OHM reading on each sensor. Orange connector. 2 wire on each.
Old Nov 7, 2005 | 11:17 AM
thanks guys will check on wires
Old Jul 15, 2010 | 06:37 AM
purekoryo's Avatar
So what was the exact problem and solution to this?
Old Jul 15, 2010 | 07:54 AM
Rubn1out4GudLuk's Avatar
First, delete the other 2 posts from the triple posts you put up of the same question back to back(to back). The answer has been given earlier in the thread. Most likely the ABS sensor will have to be replaced. The key is finding which one(s) went bad.
https://www.s2ki.com/forums/index.php?act=S...0#entry15463817
FromaDB2toanAP1
May 9, 2015 12:02 AM
Hyper_R
Jun 23, 2008 10:57 PM
RXDI
Dec 27, 2006 03:43 PM
Costas
Oct 14, 2006 10:31 PM
KaMxiKaZe
Apr 13, 2004 04:11 PM
