HELP! ap2 retainers
Old May 15, 2017 | 09:37 AM
yamaha6611's Avatar
Default HELP! ap2 retainers
Is the spacing on the keepers ok? Big gap on one side nothing on the other
Old May 15, 2017 | 09:42 AM
Slowcrash_101's Avatar
Spacing is fine, as long as they're at the same height. Turn the engine over a few times to make sure they're seated properly, or use something wooden and a hammer and tap the stem tips(not the retainers).
Old May 15, 2017 | 11:04 AM
yamaha6611's Avatar
Yeah, I did hit the tips of the valves everything looks fine I think I'm just paranoid. I did lose one keeper, so I had to use one of the old ones, I really hope it's in the garage somewhere but I can't find it
Old May 15, 2017 | 11:08 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If you lost a keeper (ap2) and used an old one instead (ap1) on an ap2 retainer, I promise you the valve will break.
Old May 15, 2017 | 01:42 PM
rpg51's Avatar
I'm curious - why do the two depicted valves stem tops and the two retainers look so different color wise? Is it just the lighting?
Old May 15, 2017 | 02:30 PM
fernando.'s Avatar
This.
Lighting probably.
Old May 18, 2017 | 05:05 PM
yamaha6611's Avatar
why is that? i inspected the keepers and they look identical.... im not doubting you i just would like to know the answer why...
Old May 18, 2017 | 05:17 PM
Billman250's Avatar
Top Answer: 1
There is a distinct 1 degree of taper difference between the two parts. This is why they have different part numbers.
The difference between the two cotters/keepers is near impossible to see by eye.
Take this to the bank...get two new AP2 retainers, and put them in the one valve in question (the valve with the one ap1 retainer)
Old May 19, 2017 | 04:05 AM
yamaha6611's Avatar
Absolutly. I am calling Honda now. It was on cyl #2 so it's an easy fix. Do you think I'm OK to drive the car today? I know that. ..on the intake side I did this with the keepers. ap2/ap2. Ap1/ap2.
so technically I only need the 1 that I lost. .. but I'll still order 4 new ones and just redo that cylinder
Old May 19, 2017 | 04:14 AM
yamaha6611's Avatar
i just called honda and ordered the new cotters, they wont be in until MONDAY!
