Help!!! grinding noise
Old Mar 31, 2001 | 08:28 PM
jas2k's Avatar
I just picked up my new S2K today!!! While driving it I noticed when I am taking off from a dead stop, once the clutch is about 3/4 of the way out I am getting a grinding noise in 1st gear. Any ideas what this is?
[Edited by jas2k on 03-31-2001 at 10:57 PM]
Old Mar 31, 2001 | 08:37 PM
mingster's Avatar
[QUOTE]Originally posted by jas2k
[B]I just picked up my new S2K today!!! While driving it I noticed when I am in 1st gear at around 3K rpms I am getting a grinding sound.
Old Mar 31, 2001 | 08:41 PM
jas2k's Avatar
Yes, it is a 2001 with only 10 miles on it. I am depressing the clutch all the way as well, but am still getting the grind sound. It is happening during acceleration in 1st gear only? Any ideas?
Old Mar 31, 2001 | 09:39 PM
Jay Li's Avatar
The 1-2 grind occurs when you shift, not when the car is still in gear. You may want to take your car to the dealer to check it out, sounds like it could possibly be the clutch rattle.
Old Mar 31, 2001 | 09:59 PM
jas2k's Avatar
Actually I stand corrected from the way I orginally described the problem (I edited my original post). The grinding is coming when I am taking off from a stop and the clutch is about 3/4 of the way out.
Old Apr 1, 2001 | 07:47 AM
jguerdat's Avatar
I also get a "growl" from the rear when lugging the engine and starting to move. Add some RPMs and the noise doesn't occur. I believe, but can't prove, that it's an artifact of the Torsen differential.
Old Apr 1, 2001 | 04:25 PM
Utah S2K's Avatar
Check your clutch adjustment or have your dealer do it for you. Sounds like your out of adjustment......
Old Apr 1, 2001 | 05:18 PM
jas2k's Avatar
Thanks for all the advice, hopefully it is just a clutch adjustment. It seems the higher I rev from take off, the less the noise. Would this still be inline with the clutch being out of adjustment?
Old Apr 5, 2001 | 07:24 AM
jas2k's Avatar
Update on my 1st gear grinding noise. I noticed when the vehicle is "cold" it does NOT make the grinding noise when taking off from a dead stop in 1st gear. After about 7-8 minutes of driving, and when the car is warm, is when the grinding noise appears. Any ideas why the temperature might effect this? Any help would be extremely appreciated.
Old Apr 5, 2001 | 07:55 AM
netwiz's Avatar
how many revs are you turning? I've noticed that one of the tension pulleys (maybe the cam chain idler pulley) makes a rattle at low (1-2k RPM) revs when accelerating. I had something similar in my '01 Corvette. I've been ignoring it, or starting out at a higher RPM. The engine makes no power below 2k anyway...
