Help help help
Old Nov 19, 2024 | 06:47 PM
engifineer's Avatar
Improper cam timing did not do that to the cams. Those cams were starved of oil. Improper timing would either not run at all, run like crap or if too far off would have caused contact of valves to pistons. But those chewed up cam lobes were oil starved. Unless I guess you are saying they did not even bother torquing them which I guess they could not have properly if the bolts were stripped, which could cause that damage. Damn. So much ton unpack there but they sure screwed that one up!
Old Nov 19, 2024 | 07:42 PM
windhund116's Avatar
Could improper torquing of the cam bolts lead to too low oil pressure on the cam bearings --- and damage?
Thanks!
Old Nov 20, 2024 | 03:56 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
In order to replace the cam towers, you need a 10pc matched set of upper and lower caps. You do not need a cylinder head.
JAYDM919
Aug 13, 2020 04:38 PM
gfunkitron94
15
Nov 24, 2018 02:41 PM
AnthonyB
Nov 18, 2005 05:25 PM
4IGS2000
Nov 18, 2001 09:00 PM
