Help! i got a cel!
Originally posted by ideugene
s2k_zonie... before i reset the CEL ill try to see what exactly the code is just to make sure
Doc... i only get premium 93... always from the same gas station... and i never had a problem before... although theres always a first... could it be that i sucked up water from my cai?
does anyone know how much it would cost to get the dealer to pull the codes from the car? or is it just worth getting a obd2 scan tool?
do you guys think itll be ok if i drive the car around?? the dealership is a good 20 minute drive... and even then theyre so busy id have to make an appointment and go at another date... but in the meantime i have things to do... i just dont want to damage anything further... what you guys think?
Everyone should buy themselves an inexpensive OBDII code scanner. You'd be amazed at how easy it can be to pull codes and fix your car yourself. The light could mean hundreds of different things. Could be a simple evap leak, like a loose gas cap, or something major that will serverely damage the emission controls and/or the engine. Have to scan it to be safe. OR, you could do a limited scan without a scanner by extracting the codes via flashing of the CEL. See modifry's website for details.
Will save you quite a bit of headaches especially when you mod anything at all on your car.
Here is what the Helm's Manual says:
P0132 - Primary Heated Oxygen Sensor Circuit High Voltage
Troubleshoot.
1. reset the ecm
2 start the engine. hold engine at 3000 rpm with no load (in neutral) until the radiator fan comes on.
3. Test drive under following conditions:
-55mph steady speed
-M/T in 6th gear
-until readiness code or Temp DTC P0133 comes on
4. Check for a temproaray DTC with the scan tool
Is there a temp code of P0133?
Yes - replace primary O2 sensor (Sensor 1)
No- intermittent failure, system OK, check connections.
So if you reset it and drive it as above and the CEL doesn't come back on, it was probably just a fluke from you running out of gas. Give it a shot and see what happens.
Good Luck
JJ
Troubleshoot.
1. reset the ecm
-55mph steady speed
-M/T in 6th gear
Good Luck
JJ
thanks
