Help Idle air control valve IACV part #'s
Hi,
So I need to buy the hoses that connect to the IACV
as well as the screw/bolt that screws underneath the throttle control actuator. i've been referring to it as the idle control screw, but don't know the actual name or part number. if someone could please direct me in the right direction that would be crucial!
http://www.hondaautomotiveparts.com/...ry5=WATER+HOSE
#6 and #7 are the two hoses.. although, there's nothing special about them, and generic coolant hose replacements with the correct inner diameter from auto parts store should suffice.
Not sure what screw you are referring to. Perhaps you can find it in this diagram
http://www.hondaautomotiveparts.com/...=THROTTLE+BODY
I need to change this part because I have coolant smell and the greenish stain like someone said in another thread.
"If you are going to have a leak it will be the smaller hoses that run from the idle air control valve to the throttle body and across to the intake manifold, check the ends of those hoses for any greenish stains. They can leak small droplets that evaporate quickly and often don't make it to the ground"
Somebody know the part number?
Thanks
windhund116 (04-26-2023)
