Help...issue at start up
Old Oct 18, 2014 | 06:42 PM
Gbcrebel13's Avatar
Default Help...issue at start up
So the other day I went to take the S the work and started her up, right after the engine started there was a quick loud grinding noise almost like you turned the key on a normal car after it was already running. I took my DD that day instead and changed the oil that night just in case. Put new oil in and started the car...all was good. Drove the car for 2 days no issues. Then this morning it did it again. I park in the garage and I will say it was by far our coldest night since like March (FL weather) both mornings I had the issue. Any ideas? Thanks!
Old Oct 18, 2014 | 06:55 PM
daileyboy81's Avatar
Eh.. No worries here. Mine has been doing the same as the weather gets colder. I've done a bit of research and it seems like the norm noise for our starters to make when it starts getting cold outside.
Old Oct 18, 2014 | 08:20 PM
Gbcrebel13's Avatar
I've had the S though winter before and never had this problem...could starter be going?
Old Oct 18, 2014 | 09:36 PM
franky's Avatar
Looks like u guys got a sticky starter. Overtime the small gear in the starter tat sticks out to rotate the flywheel, gets a lot of buildup dirts or debris n it stays stick out longer than usually n cause it to grind against the flywheel as it retracks back. Its normal.
Old Oct 18, 2014 | 09:42 PM
Gbcrebel13's Avatar
thanks...thats what I figured, looks like I'll be on my back next weekend, would rather replace the starter now than f up more stuff and have to replace the flywheel too.
Old Oct 21, 2014 | 12:32 PM
cinaibur's Avatar
Former Sponsor
I wouldn't worry about it. Mine has been doing this for 4 years and 50k miles. It goes away completely in the warn months. Once it starts gettting colder it will grind. I have figured out just the right time to let off the ignition and I can keep it from grinding 80% of the time.
Old Oct 21, 2014 | 01:36 PM
Slowcrash_101's Avatar
Mine does it depending on humidity.
sanchez
Aug 21, 2013 10:47 PM
sal_flip
May 20, 2010 01:24 PM
Scrufy
Aug 31, 2006 03:12 PM
shittles
Nov 26, 2005 11:13 AM
simons2k
Feb 13, 2003 05:58 PM
