HELP ! knocking coming from rear ?
Old Jan 3, 2011 | 04:11 AM
GT 52DDD's Avatar
after Jacking the car up yesterday i still couldnt find anything loose... i suspect that it may be the ball joints because thats the only part that looks a wee bit worn but i still cant see any play in it...
Old Jan 13, 2011 | 03:41 PM
ronnuke's Avatar
The part I was referring to is 52748-SM4-014 016 002 RUBBER, SPRING SEAT (SHOWA)
On http://www.hondaautomotiveparts.com/auto/j...+SHOCK+ABSORBER
Old Jan 14, 2011 | 05:06 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Check your sway bar end links number one cause for clunks over bumps.
Bad inner CV joints do not make noise.
Old Jan 14, 2011 | 05:08 AM
Billman250's Avatar
Top Answer: 1
It is not the rubber seats either.
Old Jan 14, 2011 | 07:25 AM
-Jordan-'s Avatar
What do the coils look like? Some springs have "dead" coils that require insulation to reduce noise, decreasing stiffness maybe causeing the springs to clamp when the compress?
Old Oct 9, 2012 | 05:25 AM
tarielk's Avatar
Sounds like I have the exact same problem! Cannot figure out what my problem is!! I'm running HKS Hypermax III Sport coilovers.... Pls let me know If you have found what was wrong and how to deal with it!
Old Oct 9, 2012 | 06:39 AM
rjones's Avatar
I also get one clunk when taking off on a left hand turn. I through it was the axel nut, but I tightened it and the nose is still there. I am going to pull the wheel and see if I can find anything lose. I have looked under the car and didn’t see anything. The car feels fine.
Old Oct 9, 2012 | 12:57 PM
S2KHANG's Avatar
retorque the axle nuts??
Old Oct 10, 2012 | 03:45 AM
tarielk's Avatar
I did that? didn't help, still hearing that dreadfull sound.
MuckaLun
Mar 19, 2008 05:43 AM
moff
Sep 7, 2007 11:32 AM
iNetForce
Mar 18, 2007 06:11 PM
(S2K4ME)
Feb 6, 2007 01:11 AM
milo coon
Nov 13, 2002 07:09 AM
