Help! Looking for a crank/cam signal scope
Old Nov 10, 2006 | 02:47 PM
mx5's Avatar
mx5
Thumbs up Help! Looking for a crank/cam signal scope
Does anyone have to a oscilloscope graph (or diagram) of the S2000 crank cam setup?
I know the cam signal has 3 pulses per engine cycle (at TDC of 3 of the cyliders)
And I also know that the crank wheel has 12 teeth (24 pulses per engine cycle)
But I am looking for more info - where exactly are the 3 pulses, and how do these overlay with the crank pulses, width, position, etc.
Old Nov 11, 2006 | 08:25 AM
mx5's Avatar
mx5
bump
Old Nov 11, 2006 | 03:20 PM
Slows2k's Avatar
This is a pretty specific question that the majority of the S2k owners would never need to explore. You'll probably need to hook up a scope to your car for the answer.
Old Nov 12, 2006 | 06:56 AM
Ek9's Avatar
Ek9
Banned
You'd probably be better off going to AEM's EMS forum and asking there. They have to have intimate knowledge of the pulses in order to tune for it.
Old Nov 12, 2006 | 07:39 AM
milkbubble's Avatar
Here is a scope wave form library but you have to be a member.
http://www.iatn.net/premium-membersh...m-library.html
Old Nov 12, 2006 | 06:58 PM
milkbubble's Avatar
Hey if you can get a hold of a scope with a dual trace set up you can trace 2 patterns on the same screen and compare them. You can set up the ms/ divison to make it easier to read so you can see the reference tooth pattern on the cam/ crank scope pattern and see how they are timed in that aspect...
classicvin
Apr 7, 2016 04:41 AM
Keith P
NYC Metro Stock Exchange
Jul 1, 2014 07:53 AM
Moddiction
18
Apr 11, 2009 05:21 AM
whitetiger777
Apr 20, 2006 07:21 AM
batikan
Feb 28, 2006 09:56 PM
