Help me analyze a poor compression test
Old May 9, 2011 | 11:13 AM
durtysocks's Avatar
Default Help me analyze a poor compression test
I bought an '05 s2000 with 62,000 miles. the car drives well.
I have been in the normal maintenance kick that usually happens after buying a used car. Typical things, engine oil, trans oil, diff oil have all been changed.
Today, I got to the compression test.
Starting from the front:
170
210
220
150
Ok, it was bad news. I can handle it. I have been trying to get an idea as to why one and four would be lower. Could this be valve clearances (this would be my hope)? I was going to inspect/adjust them anyways. But I'm fairly certain that when clearances go, they go loose, which wouldn't effect a compression test.
Any ideas other than a leakdown?
Old May 9, 2011 | 11:20 AM
suzuka-blue-s2k's Avatar
Not sure what else to tell you except for getting a leakdown test done so you can figure out exactly what's going on with it.
Old May 9, 2011 | 01:15 PM
steven975's Avatar
Actually many have said their valves went tight.
Mine went loose, though.
jpetch05
Oct 12, 2013 06:05 AM
S2KPUDDYDAD
Tampa
May 8, 2013 08:39 AM
evoluder
Feb 3, 2012 12:52 PM
JDMQuip
Oct 29, 2009 01:14 AM
mrkim019
Nov 28, 2005 10:02 AM
