Help misfiring codes
Old Dec 4, 2011 | 03:12 PM
Imbruceyo's Avatar
Default Help misfiring codes
I have a 2000 ap1 91k miles. I'm throwing misfiring codes
P1399
P0304
Sometimes it say it's misfiring in all cylinders..
P0300-p0304
My car idles rough, when I pull out the coilpack on cylinder 4 idle does t drop down. Coil pack gets super hot. Even after I rotate coils. The coils I put into cylinder for will get hot immediately. Car also sputters from 2-3k.
At first it used to run rough on cold starts, the. Would drive find when warm. Recently the s2 has got worst now the cel is flashing. Runs really rich
I have read hundreds forums and know of all the possible problems. Before I start spending money I don't have. Where should I start?
Clean map sensor Zip tied
Spark plugs look ok
Coil packs look fine
Old Dec 4, 2011 | 03:15 PM
99SH's Avatar
Have you read this post?
https://www.s2ki.com/s2000/topic/659930-misfire-thread/
Old Dec 4, 2011 | 03:17 PM
Imbruceyo's Avatar
Anyone know why only cylinder 4 coil pack would get hot after having the car on for seconds while the other 3 stays cool?
Old Dec 4, 2011 | 03:24 PM
99SH's Avatar
That cylinder may be running lean. Check injectors & valve lash
Frank
May 6, 2014 06:27 AM
pghs2kid
Jul 17, 2013 06:43 PM
NFRs2kevin
Feb 26, 2010 03:24 PM
mtm864
Feb 5, 2009 04:15 PM
2nd is Nowhere
Feb 17, 2006 10:22 AM
