HELP ! Overrev
Today i was in 6th gear around 70 +- mph....tried to drop it into 4th slipped into second....i didnt drop the clutch but as i released the clutch it revved up and the tach started blinking..i then put the clutch in of course. I am SEVERELY worried that i messed something up and bent vales messed up pistons and all that horrible stuff brokenheart.gif I am very paranoid right now and cannot get sleep. I dont know what i should do...if Bill man or anyone can point me in the right direction i would appreciate it!!
I have a my06. Im also running a test pipe so the CEL is there....what should i do??
-Dave
-Dave
If you dont notice a power loss then you should be fine. If you're truly worried just do a compression test, you can buy them at Sears and its really easy to do. or find a friend to do it for you, takes no longer than 20 minutes.
Have a leak down and compression test done. Remove the valve cover and inspect the valve spring retainers, and the valve lash clearance. Just to be shure. I read that this engine can turn up to 10,700 rpm, so you may be good.
Originally Posted by onfire01,Mar 4 2007, 09:44 PM
Problems arise thousands of miles after an over-rev... get it checked out
best advice yet .... if you feel you did over-rev your motor to a point where it could have damaged something ... get your valve spring retainers checked.
Well typically s2000's have been known to have the ability to run symptom free for quite a while with a cracked retainer that can later fail . . . . so it has been common practice to inspect retainers on a bad over-rev. However, Billman has said his current theory is that AP2 retainers are improved to the point where they will not crack until the point where valves would already be kissing and bending . . . . so anotherwords billman believes an AP2 (2004+ s2000) would either show symptoms right away or your okay.
Buttttt . . . you might want to just pull the valve cover and have the retainers inspected for piece of mind. The compression and leakdown test would not show cracked retainers on AP1's unless the valve has already been dropped.
