Help with shaking
Old Dec 31, 2016 | 09:34 AM
CARsLOwh2o's Avatar
Default Help with shaking
Hey everyone, recently my car has been shaking pretty hard while I was braking. It seems to be shaking from the front passenger side of my AP2. I immediately thought it was going to be my brakes that needed to be changed until finally one day i was braking while going down a steep hill and came to a complete stop and my car kept shaking??? Made me realize that it only shakes when the g force is being pushed forward just like when im braking or how i was facing downhill on a steep hill.... Any suggestions? Im thinking either motor mounts or transmission mounts. Thanks
Old Jan 1, 2017 | 10:24 AM
steelers743's Avatar
This is how you check the engine mounts...I would say that or rotors
Originally Posted by Billman250
That thread got dumped by the topic starter.
Yes you can put a long pry bar under the corner of the throttle body, and pivot off the shock tower bolt to check for a broken mount.
Other side you can use the VTEC valve.
It may sound crud, but it only takes gentle pressure to lift the engine up by it's side.
Pry gently. A good mount will flex and stop. A bad mount will knock up and down.
Trans mounts can be checked by hand just by lifting on the back of the trans by hand.
Dif mounts inspect visually.
black_EM1
Oct 14, 2011 08:12 AM
hybridspl
Tampa
Apr 23, 2010 04:09 PM
ttang
Nov 9, 2008 10:18 AM
GT_NFR
Dec 18, 2007 02:22 PM
