Help! Spacer problems!
Old Apr 24, 2007 | 02:53 PM
JsRacingS2K's Avatar
Default Help! Spacer problems!
I have recently installed H&R 25mm front, 15mm rear spacer on my car.. now my car is making this squeeking noise when it comes to a stop or reverse.
Sounds like metal scratched.... is this sound NORMAL??
Old Apr 24, 2007 | 03:05 PM
RED MX5's Avatar
Are you sure the tires aren't hitting the fenders somewhere?
Old Apr 25, 2007 | 12:02 AM
nope, there is a gap in between... and the sound certainly don't sound like tires rubbing... it sounds like metal disc scraping...
Old Apr 25, 2007 | 05:23 AM
FISH22's Avatar
possibly wheel bearings/hubs.
your bearings could have been in not so good condition before the spacer install, and after putting them on, it could have just made it worse.
Old Apr 25, 2007 | 06:32 AM
freq's Avatar
Need brake pad?
Old Apr 25, 2007 | 11:52 AM
RED MX5's Avatar
Well, without hearing the sound I can't even venture a decent guess. I think I'd take the spacers off and see if the noise goes away. At least that might narrow it down a little.
Old Apr 25, 2007 | 11:32 PM
I'll get it checked out... see if i can pin point the problem out... thanks for the help!!
Old Apr 26, 2007 | 12:22 AM
sean2sean's Avatar
did you get your studs replaced? if so... who took apart your hub? they prob didnt install the bearings correctly.
warrenk05
Oct 13, 2020 02:31 PM
musicforthedeaf
Sep 17, 2015 10:10 AM
seoul2k
Mar 21, 2010 03:15 PM
mattfeet
Sep 17, 2009 01:00 PM
jguerdat
Nov 12, 2004 12:08 PM
