HELP! steering wheel was stolen
Old Apr 23, 2009 | 03:42 PM
twofast4u's Avatar
Default HELP! steering wheel was stolen
I bought another one from a member on here, and installed it. (very easy) However that wasnt the only problem. My horn doesnt work, the srs light is on the dash, and finally I dont have the cruise control buttons. I'm sure I can get the cruise control buttons and install them. Please tell me what I need to have a functional horn, and fix the srs issue. Thanks in advance for the help!
Old Apr 23, 2009 | 03:50 PM
CKit's Avatar
Not S2000Talk.
Old Apr 23, 2009 | 03:54 PM
Nate4635's Avatar
2 ohm resistor between the SRS leads to simulate an airbag (which you dont have anymore) will get rid of the SRS light. However, once on you need to go through the reset procedure, should be able to search for it.
The horn is simple, assuming you have a horn button with your wheel. The hub you have should have some kind of connection for it, its just 2 wires, hook them across the horn button.
Old Apr 23, 2009 | 04:57 PM
negcamber's Avatar
What year car was the steering wheel from?
Old Apr 23, 2009 | 05:24 PM
Slows2k's Avatar
What kind of steering wheel you installed would also help.
Old Apr 23, 2009 | 05:35 PM
twofast4u's Avatar
2002, and i replaced it with a stock steering wheel
Old Apr 23, 2009 | 05:37 PM
iam7head's Avatar
functional air bag?
does it comes with any of the pig tail?
Old Apr 23, 2009 | 05:38 PM
Slows2k's Avatar
Did you plug the airbag and horn wiring in?
Old Apr 23, 2009 | 05:41 PM
Nate4635's Avatar
opps...disregard my post then, I thought you meant replaced it with aftermarket...
Like other have said...just plug it in and you should be good.
Assuming you did that, check the ground for the horn, and the mechanism for when you press the airbag in completing the circuit.
And do the SRS reset procedure, and I'm sure your light will go away assuming the bag is plugged in.
iam7head's Avatar
i was trying not to say this but..well
anyways, SRS light should stay lite unless you reset it
