Help! Stumbling at Idle
Originally Posted by Race Miata,May 17 2006, 11:00 AM
I'm wondering what all that brown residue on the back white part of the plugs is. Would that be a sign of plugs backing off? Were those plugs loose when you removed them?
brown residue was dirty dielectric grease i think. plugs were not loose. I also still have the original honda "s" marked plugs i removed in december, they look the same (black)
not sure, but i think there was a vafc on at one point in its life before I bought it.
Guess i'll look into getting it to a dealer somehow. I definetly can't drive it the 50miles to the closest one.
Depending on how good the dealer is diagnosing the problem, it could be the best way to have this fixed. Alternatively, you can try decarbonizing the combustion chambers, replacing the O2 sensor and plugs. In either case, keep monitor the plug status once the problem is fixed. When you see the ceramic portion of the plug inside the combustion chamber is getting black again, you know the problem is not fixed at its root.
EVAN_In_A_SPA
Feb 11, 2010 05:07 PM
