help! ticking noise
Old Mar 23, 2010 | 07:36 PM
osidis's Avatar
Thumbs up help! ticking noise
i am a little worried about a ticking noise in the front of the engine. i dont think its the valves because they are hydraulically adjusted right? i havnt really beat on my car either. i only use the best oils and fluids.ect. so i am guessing that the noise is the cam chain. i have an 04 s2k, 66k on the stock motor. whats could be going bad? cam chain tensioner? chain guides? chain? what? please help. is the tensioner hydraulic or spring loaded? what is involved in the repair? i can do it myself if i had the instructions. anyone willing to help?
thanks,
oz
Old Mar 23, 2010 | 09:03 PM
ronnuke's Avatar
Check out the FAQ, DIY section and find the thread about Timing Chain Tensioner.
Old Mar 23, 2010 | 09:04 PM
ronnuke's Avatar
https://www.s2ki.com/forums/index.php?showtopic=544760
Old Mar 24, 2010 | 12:38 AM
SUPERAnimal's Avatar
Also, the valves aren't hydraulically adjusted. You adjust the valve lash mechanically.
Old Mar 24, 2010 | 08:50 PM
osidis's Avatar
thank guys, sounds easy enough. being a helicopter mechanic, it cant be to hard. i need an oil change anyway. if that dont fix it, then it has to be the valves. adjusted at 66k? seems a little soon. guess i can check the valve clearance too while im there under the hood anyway. im not to worried anymore though....i am planning on having "the old one" build my engine this coming winter.
Old Mar 24, 2010 | 08:53 PM
XenonKiller99's Avatar
Ticking noise near engine...I bet 95% it's TCT(Timing Chain Tensioner). I've replaced mine at about 63,XXX miles...I also did 'Valve Adjustment' and replaced 'ignition coil packs' at the same time(both not the problem) but helped eliminate my check engine light.
Old Mar 25, 2010 | 08:57 AM
liquidride59's Avatar
I did my TCT at 62xxx miles... I'm around 70k now and its starting to happen again... idk maybe I got a bad TCT I did a valve adjustment at the same time of the first TCT install...
Old Mar 25, 2010 | 12:25 PM
hyperkin's Avatar
i would say do the oil change first, i changed my oil last weekend, and the engine noice just gone. before the oil change, the car has the "card on the bicycle wheel" sounds from 2.5k-4k rpm, after the oil change, it is way way way less than before, barely noticable.
well, it was the first oil change on my car... now i dun even notice much of the engine noise.... all i hear is the intake!!
and only 15% oil left before i did the oil change....
hope those helps...
Old Mar 25, 2010 | 02:49 PM
drewmob's Avatar
Old Mar 26, 2010 | 02:49 PM
osidis's Avatar
thanks all! i got the tct. i will be putting it on tomorrow along with oil change.
shanepotter
Jan 28, 2016 02:15 AM
landos2k
Oct 25, 2015 05:47 PM
blink962
Sep 17, 2009 04:09 PM
strar8
Sep 19, 2008 01:39 AM
