Help with Torque Specs
Old Feb 3, 2018 | 07:11 AM
Chrisn01's Avatar
Default Help with Torque Specs
Heys guys
Had a look through the manual, but cant seem to find anything. Does anyone know the torque specs for the three bolts that hold the clutch release guide & also the two bolts that hold the clutch fork bracket & sping clip?
Cheers fellas
Old Feb 3, 2018 | 10:53 AM
hecash's Avatar
Veteran: Marine Corps
flanders's Avatar
Release bearing guide 12Nm and 27Nm for the release hanger spring, it's on page 13-55 in my manual.
Old Feb 3, 2018 | 02:05 PM
Slowcrash_101's Avatar
I think every 10mm bolt on the car is 8.7ft lbs.
Old Feb 3, 2018 | 07:01 PM
Chrisn01's Avatar
Thanks guy, much appreciated :0)
Old Feb 4, 2018 | 06:42 AM
zeroptzero's Avatar
That's true , I think there are a couple bolts that go into aluminum around the valvecover that are down to 7.9 give or take, but for the most part the majority are 8.7.
Old Feb 4, 2018 | 09:04 AM
flanders's Avatar
I just installed the abs cable bracket which use M6 bolt or "10mm" as some seem to call them, those calls for 7.2 ft lbs
Old Feb 4, 2018 | 09:09 AM
Oh and the pressure plate bolts, but those are 12 point.
merkis1024
Sep 10, 2023 08:43 AM
sscott0203
May 30, 2010 10:33 AM
v2deLsoL
Dec 29, 2007 04:20 AM
Gink5
Mar 9, 2006 02:04 PM
rev_addict
Sep 11, 2002 10:38 AM
