Help with VTEC please!
Old Feb 28, 2014 | 01:21 PM
ninjas r everywhere's Avatar
Default Help with VTEC please!
Okay, so VTEC isn't working and I can't pin down a definite reason for the issue.
I have - 2003 model
- with a Comptech supercharger kit with aftercooler
- 3.0" pulley
- running a Haltech PnP ESM
- with 1000cc injectors
I took the car down to Jacksonville, Fl. to be tuned by Mase and after half a day on the dyno, we couldn't get VTEC to engage.
- We used a voltmeter to make sure the VTEC solenoid was getting the signal and it was.
- Oil level was just below the High marking on the dipstick
- I have installed an oil pressure gauge
* between 15 and 20 psi at idle (1000 rpm)
* about 75 psi at highway speeds (3500 - 4500 rpm)
* When going WOT to engage VTEC the pressure drops to around 60 - 65 psi but then rises back up to 75 psi
* I have tried replacing the VTEC solenoid with another used unit from a member here
- I have made sure the VTEC filter screen is clear of any debris
Does this sound like the oil pump is going out, or am I looking at something worse? Any help or suggestions would be greatly appreciated because this is about to drive me crazy. Thanks!
- TJ
Old Mar 1, 2014 | 05:38 AM
Anybody have any idea whats going on here?
Old Mar 3, 2014 | 06:40 AM
Is this not in the correct sub. Or does no one have any kind of input?
Old Mar 3, 2014 | 09:13 AM
wadzii's Avatar
Banned
check for busted rocker arm or loose cam caps.
Old Mar 3, 2014 | 12:17 PM
MM3Kwolik's Avatar
Or a missing rocker/roller pin.
Old Mar 3, 2014 | 12:45 PM
Yea, I was really hoping it wasn't the rocker arms, but it's a pretty high mileage engine. I guess I need to figure out how to check that.
Old Mar 3, 2014 | 12:57 PM
postman's Avatar
If the solenoid is activating correctly the issue is probably in the cylinder head somewhere. Rockers or cam journals
Old Mar 3, 2014 | 01:53 PM
My oil pressure is also a little low compared to some of the others I've seen posted around here. Any chance that the oil pump could be part of the problem? Or what would I be seeing if the oil pump is dying?
Old Mar 4, 2014 | 05:05 PM
Well, I've decided to take it to the stealership to get some professional eyes on it. I'll update when I know for sure what's going on. Thanks for the help thus far.
Old Mar 4, 2014 | 06:14 PM
apme123's Avatar
take a modified car to a stealership are you freaking crazy, i wouldn't take a honda lawn mower there. Find a shop that specializes in S2000's or honda vehicles
