Help weird sound after changed spark plugs
Old Dec 17, 2018 | 07:08 AM
saulfeng's Avatar
Default Help weird sound after changed spark plugs
My engine light showed up a few days ago. And I took the car to a shop to check it. And they said it’s spark plugs problem. So they changed all four spark plugs. Engine lights was gone. But I feel weird about the engine sound when my gear is in nature. The sound just like the spark plugs been changed before. Suddenly big and suddenly small. And I don’t want to drive it back to them. It’s too far a way. Please help
Old Dec 17, 2018 | 07:35 AM
starchland's Avatar
Presumably you had a misfire code? the sound started after the shop changed the plugs is what I'm understanding?
Old Dec 17, 2018 | 07:36 AM
saulfeng's Avatar
yes
Old Dec 17, 2018 | 08:12 AM
starchland's Avatar
Verify the plugs are tight
don't drive the car
Old Dec 17, 2018 | 08:15 AM
saulfeng's Avatar
don't drive the car
ok thanks. Is there any other problems it could be?
Old Dec 17, 2018 | 09:59 AM
starchland's Avatar
Would be nice to see the old plugs
Old Dec 17, 2018 | 12:31 PM
Car Analogy's Avatar
If plugs aren't tightened to proper torque spec, they can come loose. If this happens, it can cause detonation. This is what we worry you are hearing.
Because this will soon cause spark plug tip to break off, which will then destroy that cylinder. It will destroy your engine!
That is why you should check to make sure plugs did not come loose.
Honda realized that their original torque spec for how much to tighten tbe spark plugs was not enough. So they changed it, and made it higher. If the shop found the old spec, and went by that, this would he your problem.
So not only make sure the plugs are now tight, but also make sure they are tight enough.
The old spec was 13 ft/lb (17.6 nm)
The new spec is 18 ft/lb (24.4 nm)
But the most well respected S2000 mechanic in the world suggests to use 24 ft/lb (32.5 nm)
Old Dec 19, 2018 | 05:05 AM
nubbel's Avatar
Broken spark plug thread @ 25lb: https://www.s2ki.com/forums/s2000-un.../#post21345758
Maybe stick with the updated OEM values or somewhere inbetween?
Nevermind, Billman broke them @ 80lb
https://www.s2ki.com/forums/s2000-un.../#post23996215
Old Dec 19, 2018 | 06:12 AM
liybzd's Avatar
Did you have them changed in Ballade?
Old Dec 21, 2018 | 01:02 PM
SpitfireS's Avatar
Does the rpm change when you hear the sound?
Do you only hear it around the engine or also at the end of the exhaust?
What fuel are you using?
The car was fine before the check-engine light came on?
We're talking about the check-engine light and not the oil pressure light, right?
Anything happened before the check-engine light came on?
Did the shop tell you the error code?
Thateguhate
May 2, 2014 07:02 PM
The Hoth
Jan 20, 2009 11:24 AM
s2k_suprchrgd
Aug 28, 2005 01:44 PM
emc2
Sep 2, 2002 01:20 PM
bartonh
Jul 18, 2001 06:33 PM
