Spark Plug Torque
I had a spark plug back out on me. Granted I was at the 20ish torque I am hesitant to up it that much more than the 22fp I just set it at. I will be re-checking the plugs(that one in particular) every 1,000 miles till I can be assured that that one isn't backing out at all.
Yes I'm sure a lot of people think that about torque wrenches.
All torque settings are for installing a fastener and tightening it.
Resistance (not torque) increases as things sit motionless. Some physics are involved with why a torque wrench cannot be used to check a currently tightened bolt. Not sure I can explain them
Bottom line, the breakaway torque is higher on a bolt that is not moving. So it may take 30ft-lbs to break a bolt loose that is only 25 ft-lbs.
This is where "mechanics feel" comes in.
Again - just as Billman stated: 21 ft lbs is the recommended torque to prevent the sparkplug from backing out (every S2000 savvy Honda mech/tech that I have spoken with uses this spec). As a few have noted - the Helms manual states 18 ft lbs. However, the problem (especially with new plugs) is the initial torque falls off slightly in part due to the washer on the plug.
I set mine between 27 and 28.5 NM which is right at or slightly below 21 ft lbs. If you're re-torquing plugs that have been in there for a while, I personally bias toward 19-20 ft lbs. 1-2 ft lbs over the spec'd torque will not hurt anything, especially considering most consumer market torque wrenches have a +/- accuracy range of 3-10% depending on the quality and fidelity of the wrench - which is a function of and partially based on the percentage the target torque is relative to the overall range of the torque wrench.
Someone noted an over-torque situation resulting in a damaged plug:
25 ft lbs won't strip out or damage a spark plug - I would be willing to bet either there was existing damage, the plugs were legitimately over-torqued previously, and/or the torque wrench is well out of calibration or lacking the fidelity for more delicate torque levels.
I personally use an inch-lb wrench (with a range in NM for ease of reference) for things like spark plugs - it provides better feel and the resolution needed for things like spark plugs. You should never use a torque wrench designed with a range that extends in to the triple digits for spark plugs. They can have significant slop at the low end of the range and can be easily off by several foot lbs.
Just do what the factory says...like 100k miles. I don't see any point in trying to fix something that isn't broken, especially if it could end in a destroyed engine. The factory isn't going to say 100k miles and then not have it last as long. If anything they are going to say 100k on an item that can actually last 200k.
My dad ran his plugs 270k on his van and they were fine lol, you guys are obsessing too much.
The OEM plugs should NOT be re-gapped - you just replace them with a new set of Honda boxed OEM plugs (I'm speaking specifically toward a stock or an N/A motor that is not heavily modified). You can get essentially the same plugs aftermarket - and it might be a little cheaper. However, they may not be specifically gapped within the S2000 OEM range from the factory - and again, you should never re-gap these plugs. Doing so will likely damage the coating on the ground electrode. If your motor is still relatively unmodified it's best to stick with the Honda boxed plugs - but pull them every 30,000-50,000 miles to check the gap.
this has to do with static vs kinetic friction but im not sure that the difference between the two in this case is significant to say that it wouldnt be in the ballpark.
also this would render the idea of re-torquing something useless. for instance, when you install a cylinder head with a two step tq sequence. this assumes that the second step is within the range of force required to break the bolt/nut into motion. if its outside that range them im wrong. huh...just learned something
I think the 2 key points behind adding a few foot-lbs more to the 18-19 ft-lbs recommended by the FSM are 1. The obvious reason to account for possible error in your torque wrench and prevent the headaches associated with a spark plug becoming dislodged from the head, combusted and later uncombusted air-fuel entering the spark plug tube, melting coil pack and potentially damaging the delicate aluminum head. 2. Torque force is compromised by using the deep 5/8 socket and 6in extension required for spark plug install, so adding a few lbs is advisable. I start by hand tightening then torque to 21lbs and have been tracking the s$%t out of my S for 3 years now without issues!
In summary, Just do what Billman says and don't ask any effing questions!! :-)
Cheers
For the record, I did a torque test on a stock head and stock plug. Starting at 15 ft-lbs, I increased the torque by 5 ft-lbs each time to see what the threads could handle.
I reached 80 ft-lbs, and the spark plug threaded portion broken off the spark plug. The head suffered no damage at all.
This makes 24 ft-lbs a solid number you can take to the bank.
For the record, I did a torque test on a stock head and stock plug. Starting at 15 ft-lbs, I increased the torque by 5 ft-lbs each time to see what the threads could handle.I reached 80 ft-lbs, and the spark plug threaded portion broken off the spark plug. The head suffered no damage at all.This makes 24 ft-lbs a solid number you can take to the bank.
Sorry to revive such an old thread.
I'm getting ready to check the valves in my 09 DBW with 63,000 km for the first time (just read the warning thread!), but I was wondering what I should do if I remove the plugs for the valve inspection and then decide to re-use them. Should I use anti-seize paste this time (ie will the factory anti-seize coating on the plugs be worn off?) If I do use anti-seize, what torque should I use?
Is it even necessary to remove the plugs to spin the crank shaft to get to TDC in all cylinders? I've read that the compression makes it quite difficult.
Thanks for the help,
Amnesia
Amnesia
