High speed shaking normal?
Old Apr 6, 2008 | 12:24 AM
Apex_AP1's Avatar
Default High speed shaking normal?
Is it normal for my steering wheel to kind of vibrate and feel "shakey" at high speeds? I only feel this when I drive over 80mph. It almost feels as if my tires will blow out or something too. I was told by my buddy that Im due for some front tires in a few months, but not yet. The inner parts of my front tires are almost reaching the tread bars. Could that contribute to the high speed shaking as well?
Old Apr 6, 2008 | 01:24 AM
hellspare's Avatar
Check your alignment.
Old Apr 6, 2008 | 03:39 AM
mlc's Avatar
mlc
How many miles do you have on your tires? Just becuase there is some tread left on them doesn't mean that the belts inside the tire aren't seperating. Usually a shake is not do to an alignment issue. It could also just be a tire out of balance.
mlc
Old Apr 6, 2008 | 06:27 AM
BigWillieStyles's Avatar
alignment, tyres or your imagination are all likely
Old Apr 6, 2008 | 07:24 AM
RISLAR's Avatar
Try the tyre pressure's fella
Old Apr 6, 2008 | 09:04 AM
Mrfixit687's Avatar
Alignment isn't going to cause steering wheel shaking at high speeds, your tires are out of balanceHave them balanced or mount and balance new tires since you're going to need new tires soon.
Old Apr 6, 2008 | 09:10 AM
silverstone_S2K's Avatar
i had this problem too about a month ago right after i bought my s2k off the lot.....mine was due to tire balancing...
i had the car aligned the first day i bought it and then a week later the wobbling started so i got the tires balanced...fixed the problem
hope this helps
Old Apr 6, 2008 | 09:13 AM
Apex_AP1's Avatar
thanks guys, I am due for a rotate and balance anyways, I do that every other oil change. Maybe thats it.
Old Apr 6, 2008 | 06:20 PM
shotgunjimmy's Avatar
how do you rotate your tires?
Old Apr 6, 2008 | 06:30 PM
Apex_AP1's Avatar
since im staggered, just right to left I mean
