High speed shaking normal?
Okay. You do know you CAN NOT rotate your tires! The car has staggered tires, the back tires are larger then the fronts. If you have had your tires rotated I think I know what your problem is. I would get them balanced and see if that helps.
mlc
mlc
Yeah definitely cannot rotate with these tires. They are directional unless you switched the tires out.
Get your wheels and tires balanced and check tire pressure. And if you do have stock tires make sure to put them back on correctly with the directionals going the correct way.
Actually, it could be simple hardness of the tire. I was running stock 140s up front, and 3xx in the back and i couldn't keep a lane at over 100. Now that I have the 3xx's in the front and back I can easily max the car out like i used to. Make sure you have the same harness tire in front and back.
