Honda PCX Oil Filter made by Fram?!
Old Aug 19, 2008 | 10:41 AM
  #101
2007 Zx-10's Avatar
Banned
Originally Posted by 90crvtec,Aug 19 2008, 10:38 AM
However, with the oil filters I have yet to see any data that indicates using an M1 or K&N or FRAM would be an improvement over what Honda recommends for the S2000. Find me some data.
As far as I know, no direct comparison exists. However, we do know this: the Mobil 1 filters include a synthetic media which is far more effective in trapping fine particulates than cellulose media (found in the PCX) alone
1 + 1 = 2
Fram is junk...well documented
Old Aug 19, 2008 | 11:28 AM
  #102
Blacknot's Avatar
I just went out to my garage and i have 4 filters left. They all have 6 holes. So are these not as good as the 8 holes?
Old Aug 19, 2008 | 11:41 AM
  #103
jyeung528's Avatar
[QUOTE=2007 Zx-10,Aug 19 2008, 10:41 AM] As far as I know, no direct comparison exists.
Old Aug 19, 2008 | 11:59 AM
  #104
2007 Zx-10's Avatar
Banned
there is a reason why honda has given the s2000 it's own specific filter, and cannot use other Honda oem filters...
sure, the F20 and F22 have higher flow and pressure than a Civic engine, for example, that's easy to believe
does mobil 1 or amsoil address this reason that honda deems necessary to designate a specific filter design for the s2000?
the filter housing is already quite large for such a small engine imo, and the aftermarket housings are the same size as the PCX, but with better media
http://www.v11lemans.com/forums/index.php?...11&#entry105211
apparently these are also good, not sure about the price, though
http://www.baldwinfilter.com/products/lube.html
Old Aug 19, 2008 | 12:52 PM
  #105
90crvtec's Avatar
[QUOTE=2007 Zx-10,Aug 19 2008, 01:41 PM]As far as I know, no direct comparison exists.
Old Aug 19, 2008 | 01:09 PM
  #106
2007 Zx-10's Avatar
Banned
I'd like to see tests outside of Mobil's marketing department that show those special synthetic fibers to outperform the filter media in a PCX 004.
The synthetic blends out-perform pure cellulose, that's really all you need to know. The PCX is a run-of-the-mill cellulose media filter with a stiffer bypass valve; not bad, not great
At this point I have to ask you 2007 Zx-10, do you have anything outside of Mobil's own web page that shows their filters to be superior
Yes, I've posted several links that show the synthetic blend media is superior, that's well accepted fact on most forums where this topic has been debated.
forgive me for erring on the side of the people that made my car.
Honda is in business to make money, sell you a good filter that will do the job, and turn a reasonable profit, that's all they really care about. They are not in the filter business. It's been well documented they do not make the filter that you are using on your car
Do you live around the Kansas City area? I'd be willing to meet up and donate another one of my PCX 004s to the surgery block if you want to cut open an M1 and compare them.
Cutting open a filter and taking pictures has been done many times but doesn't prove anything in terms of quatifiable performance. As I previously noted from BITOG, you would need to conduct a direct particulate count comparison between both filters
Old Aug 19, 2008 | 01:15 PM
  #107
leester01's Avatar
Originally Posted by 2007 Zx-10,Aug 19 2008, 10:00 AM
I don't think the oil flow/pressure for a little 2.2 L n/a engine is going to be that high, compared to turbocharged engines in the FD or EVO, for instance...the "high flow" argument seems to be more rhetoric than actual fact
I never said "high flow" I said specific flow characteristics
As for the turbo car comparison Honda does things differently.
Getting only 100,000 miles on a sports car before breakdown or major overhaul might be alright with Mazda and Mitsu but that's what seperates Honda quality from the rest
Old Aug 19, 2008 | 01:17 PM
  #108
mikegarrison's Avatar
Originally Posted by 90crvtec,Aug 18 2008, 05:56 PM
So long as the K&N or M1 filter is torqued down really well you'd likely never have a problem using one on an S2000.
I don't know about that. A pretty high number of header oil fires have been reported with the Mobil1 filters considering how few people use them. Perhaps they were just misinstalled, but perhaps they just are not a good choice for this application.
Basically, I'll stick with the PCX004 filters. Not only are they less expensive but there is a huge number of users which provides great evidence that they are at least "good enough".
Old Aug 19, 2008 | 01:20 PM
  #109
90crvtec's Avatar
I agree with this logic as well. I just wanted to state that, if using a K&N and/or Mobil filter, the installer should torque it down well. Most of the fire threads that I've read seem to be related to the oil filter backing off thus causing an oil spray in the engine compartment.
I agree completely that the large base of PCX 004 users more than validates it as one of the best options to use on the S2000.
Old Aug 19, 2008 | 01:27 PM
  #110
2007 Zx-10's Avatar
Banned
While oil fires are certainly a concern, proper torquing of the filter should always be done, regardless. I don't see why the PCX would be any better in this regard.
Of course it's the most popular filter, but that in itself doesn't prove it's better. I suspect it's good enough (90-95% efficient) for most applications, it all depends on what performance you're looking for
