Honda PCX Oil Filter made by Fram?!
Actually, the reason most of us continue to use this filter is because it is the only filter Honda makes that is specified for just one car, the S2000.
my FD Rx-7 runs oil pressures up to 120 psi and I've never has an issue with Mobil 1 filters
Originally Posted by 2007 Zx-10,Aug 18 2008, 10:38 PM
I'm not sure this is still the case, but even if it is, there doesn't seem to be anything special about the PCX filter at all from the cut-aways on this thread
Look, I think you're a smart guy. I just finished reading the whole 8 page argument between Slipstream444 and yourself. You're new here, and you seem to like jumping into threads and making bold claims about Mobil products without doing all your research first. After 8 straight pages of arguing you finally say this:
Originally Posted by 2007 Zx-10,Aug 18 2008, 03:50 PM
I might just go over to the dark side and try the Amsoil
Its not enough to jump on here and say
Originally Posted by 2007 Zx-10,Aug 18 2008, 02:14 PM
I have $100 that says the Mobil 1 or K&N filter would blow that thing out of the water in any test of performance....the filter media looks like the usual cheap stuff found in a host of other filters
Keep in mind, I have nothing against Mobil or K&N filters. And I've already said you could likely use those filters on the S2000 without ever having an issue. But that isn't the argument here. The argument is...are those filters any BETTER than the PCX 004 when considering their use on the Honda S2000?
Well, Honda seems to think different. If there was really nothing unique about the PCX 004 Honda wouldn't spec it just for the S2000.
That's great.
But the S2000 isn't an FD RX-7 is it?
Bring some information to the table that indicates your M1 filters are better.
If you read that entire thread, you will notice I never made any "bold claims" about Mobil 1 as the "best" or "better" oil, did I? Slip did that....
However, I am confident the Mobil 1or K&N filter would outperform this "universal" Honda filter any day of the week
This thread has been beaten to death
The OP had his question answered
People posted comparison pictures and comments
Now the choice is yours on what filter you want to use
lock this puppy up!
lock this puppy up!
Originally Posted by jyeung528,Aug 19 2008, 08:29 AM
why?
why?
i'll use the one that is specifically designed for the s2000.
if someone can prove that mobil or amsoil also designed a specific filter for the s2000, using the same principle that necessitates an s2000 specific filter...then i may consider it...otherwise, i'll use the one filter that is specifically designed for the s2000.
for example, if mobile were to say "honda designed an s2000 specific filter because of this this and that...and we also did that for the s2000 and here is the filter" then i may consider it.
otherwise, it's comforting to know that honda deemed the s2000 to require a specific filter and provides it.
