Hondata?
Old Apr 16, 2008 | 08:09 PM
sik00's Avatar
Default Hondata?
Is the Hondata s300 worth purchasing or should i go for something else??? help me out if you can..appreciate any feedback
Old Apr 17, 2008 | 05:50 PM
negcamber's Avatar
You need to look closely at the Hondata website...it doesn't fit on an s2k.
Old Apr 18, 2008 | 04:55 AM
sik00's Avatar
ok that is what i thought but i was pointed in the wrong direction by someone
Old Apr 18, 2008 | 05:09 AM
ian05s2k's Avatar
you could go with the greddy e-manage ultimate. From what I have readm it is a decent system. I am currently doing research into it so I am not expert, but you might ask around about that one and people will help you out. Take it easy.
-Ian
Old Apr 18, 2008 | 09:35 AM
sik00's Avatar
thanks for the info...i will research that one myself
Old Apr 18, 2008 | 10:26 AM
D1sclaimer's Avatar
or a VAFC 2. Like the greddy, it is a piggy back ecu controller. The E-Manage changes outgoing signals from the ecu and the VAFC changes incoming signals to the ecu. Both are pretty good units. If you need to change your timing, definately get the E-Manage then. I've got a AFC Neo which is about the same as the VAFC 2 with more bling factor, but use it as a display too which the E-Manage can't do. Best thing is AEM EMS, but that would be overkill unless you're forced induction.
Old Apr 18, 2008 | 01:40 PM
sik00's Avatar
ok so i already have a VAFC 2 but not installed because i thought the emanage was a lot better
ian05s2k
Apr 14, 2012 01:41 PM
Richee
Jun 16, 2010 10:39 PM
CraigDig
May 23, 2008 10:16 AM
s.hasan546
Oct 8, 2007 07:00 PM
Venomous S
Aug 12, 2005 08:39 PM
