Horrible leakdown test result for #4
Hi,
I just went back from dealership to fix the missfires problem and the technician notes cylinder #4 shows signs of worn piston rings and 70% leakdown. I know that the engine may run bad even I didn't feel anything wrong. The engine burn about 2qt mobil one oil per 5000 miles. Want to know if I need to swap another engine asap or just find someone to rebuild the engine?
Thanks for helping me
Well, if the cylinder walls are still in good shape... You could have a machine shop hone the cylinders, replace the piston rings, and replace those valve seals. A complete rebuild is unnecessary, unless you're going for huge power (aka turbo, sc, or N/A build).
leakdown test should have told you where the problem was, either the head or the block.
used engine might be a cheaper option and I'd look into that before. Labor to work on the block isn't cheap. and it might be cost effective to find a cheap complete AP2 engine?
Save your pennies and sell your block for a project
