how to adjust the boost and tune the comptech s\c
Old Nov 29, 2003 | 10:54 PM
buffsr01's Avatar
Default how to adjust the boost and tune the comptech sc
hey i just finished the install everythig is running fine and it works but how do i adjust the boost and tune it on the comptech aftercooled sc
mike
Old Dec 2, 2003 | 11:42 AM
afetsman's Avatar
You adjust the boost on a supercharger by removing the pulley and putting on a different one. Smaller increases boost and larger decreases boost.
Not sure what you want to tune as the kit is "plug and play". But, if you put on a smaller pulley you'll probably need injectors and some tuning device like an AEM EMS or E-Manage.
Old Dec 3, 2003 | 12:56 PM
bigpurp's Avatar
You could also "tune" your VTEC engagement points and A/F ratios with a VAFC, which is what I will prolly do until I can scrounge enough $$ for a full standalone unit, like the AEM EMS.
Old Dec 5, 2003 | 04:09 AM
kstokell's Avatar
I'm in the same position as "bigburp", I'll probably go with VAFC as an interim solution untill I can afford E-manage.
Be carefull though "to lean" = "very expensive"
bublik
Apr 4, 2008 10:07 PM
ronaldng0809
Mar 26, 2008 08:50 AM
CKit
Feb 7, 2007 12:01 PM
gochuxsaurus
Nov 6, 2005 09:31 AM
my01s2k
May 26, 2005 08:58 AM
