upgrading comptech sc with 10 psi
Old Mar 11, 2008 | 12:55 PM
ronaldng0809's Avatar
Default upgrading comptech sc with 10 psi
hello guys, i'm currently running comptech SC with AC and sparco FMIC at 7 psi. Turning with AFC NEO. I would like to upgrade to 10 psi. It should be around 350rwhp or above right? Also i know i need to upgrade my injectors to 650cc and 3.25 pulley. will i be safe to keep my NEO AFC to run 10 psi?? thanks guys.
Old Mar 11, 2008 | 01:06 PM
WashabiS2K's Avatar
does the neo adjust timing?
Old Mar 11, 2008 | 01:08 PM
sorry i'm not sure. because i dont really know how to use it. my turner tune it for me.
Old Mar 11, 2008 | 02:07 PM
Soul Coughing's Avatar
i wouldnt go near the NEO or its VAFC equivilents, especially if your going to change out the injectors. you might be able to adjust fueling correctly at WOT, but the stock ECU will eventually learn the closed loop and mess up your tune. Get emanage at least, if your looking to up the power from a stock setup
Old Mar 11, 2008 | 03:24 PM
CourageOO7's Avatar
There is one guy in Puerto Rico tuning on a VAFC II and boosting pretty high values...but most of us wouldn't recommend tuning the car with an ecu that is unable to adjust timing.
No, the NEO and VAFC II do not have the ability to adjust timing. If you want OBDII compliance via a piggyback ecu, the Emanage Ultimate does have the ability adjust timing and some have had a good bit of success.
Old Mar 25, 2008 | 06:57 PM
fongaroos's Avatar
do you have any pics of the CTSC with the FMIC setup?
Old Mar 26, 2008 | 07:15 AM
nightcrawler7188's Avatar
you say sparco fmic...i think you mean Spearco front mount radiator. am i right?
Old Mar 26, 2008 | 08:50 AM
WashabiS2K's Avatar
it is a front mount radiator, not a front mount intercooler.. and if you want to see pics of the spearco setup, here is a link to Nightcrawler's thread.
https://www.s2ki.com/forums/index.ph...pic=577020&hl=
CKit
Feb 7, 2007 12:01 PM
Bibbs
Oct 4, 2006 11:14 AM
demonderrick
Sep 4, 2005 07:36 AM
buffsr01
Dec 5, 2003 04:09 AM
PanhandlingS2K
Dec 1, 2003 12:48 AM
