how to adjust idle?
Old Apr 9, 2008 | 06:43 AM
pinoyk20's Avatar
Default how to adjust idle?
hi guys!! my idle seems low and i want to meke it higher, how do you adjust your idle?? pls help me! thanks!!!
Old Apr 9, 2008 | 07:01 AM
Sideways's Avatar
If you are running a factory ECU the only thing you can do is reset it.
Old Apr 9, 2008 | 07:32 AM
pinoyk20's Avatar
where do you reset it?? i heard that you can adjust it via throtle cable???? thanks sir sideways!!
Old Apr 9, 2008 | 07:51 AM
Sideways's Avatar
It is determined electronically. Throttle cable will not work.
To reset, make sure you have the radio code and disconnect the battery for a few seconds. You can do it by pulling a fuse also.
Old Apr 9, 2008 | 08:23 AM
pinoyk20's Avatar
which fuse?? but will the idle go down if your cable is loose? thanks!!!
why does the idle go down?? my idle used to be 800-950rpm now its only 650-780rpm.........
Old Apr 9, 2008 | 08:33 AM
ubise's Avatar
thrid fuse on right column.
7.5a Back Up fuse.
i think it was orange color.
pull it out for about 1 min and put it back on.
Old Apr 9, 2008 | 08:36 AM
pinoyk20's Avatar
cool! will the ecu be reset if i removed the negative on the battery??? thanks!!
Old Apr 9, 2008 | 08:43 AM
Sideways's Avatar
Yes.
One minute is more than enough.
The cable is not the problem. There is built in slack in the cable, do not remove it.
Old Apr 9, 2008 | 09:05 AM
pinoyk20's Avatar
thanks so much guys!!!
Old Apr 9, 2008 | 09:12 AM
2poor2mod's Avatar
once you pull the fuse there is also an idle relearn procedure that you should follow. i do not know the procedure off of the relearn but im sure some searching would yield some results.
