how to adjust idle?
Old Apr 11, 2008 | 11:00 PM
  #21
Habitforming's Avatar
Here it is straight from the 2000-2005 factory service manual:
"To complete the idle learn procedure do this:
1. Make sure all electrical items (A/C, audio, rear window defogger, lights, etc.) are turned off.
2. Start the engine. Hold the engine at 3,000 rpm without load (in neutral) until the readiator fan comes on, or the engine coolant temperature reaches 176
Old Apr 12, 2008 | 12:54 AM
  #22
S2KBLanton's Avatar
Interesting
Old Apr 12, 2008 | 10:01 PM
  #23
pinoyk20's Avatar
[QUOTE=Habitforming,Apr 11 2008, 11:00 PM] Here it is straight from the 2000-2005 factory service manual:
Old Apr 12, 2008 | 11:53 PM
  #24
AusS2000's Avatar
The reason the throttle cable has nothing to do with it is that at idle the throttle is completely closed.
Air is bypasses the butterfly via the Idle Control Valve. It is this that needs to learn it's setting.
The only effect the throttle cable can have is if it is too tight and doesn't let the butterfly close properly, and this will result in too high idle.
Old Apr 12, 2008 | 11:55 PM
  #25
AusS2000's Avatar
Originally Posted by pinoyk20,Apr 13 2008, 04:01 PM
LIKE HOW LONG DO YOU HAVE TO STEP ON THE THROTLE IN 3000RPM?? THANKS!
[QUOTE]until the readiator fan comes on, or the engine coolant temperature reaches 176
Old Apr 13, 2008 | 12:21 AM
  #26
pinoyk20's Avatar
thanks sir auss2000!!!!
Thanu31
Apr 1, 2015 05:32 AM
cmflex84
Sep 12, 2004 06:59 PM
M@rk
Jul 20, 2004 01:12 PM
LIS2K
Oct 17, 2003 11:33 AM
s2kchan
Apr 18, 2003 10:31 PM
