How bad is this?
Old Nov 12, 2022 | 05:07 PM
phatcivic's Avatar
Default How bad is this?
This would fall outside normal right?
https://youtube.com/shorts/FNcVcbQMNQQ?feature=share
I am probably due for new valves but my guess is this would be piston rings if anything. No?
Old Nov 14, 2022 | 10:44 AM
bruthaboost's Avatar
Take off your oil cap and see if you have blow-by. A leakdown will be much more diagnostic.
Old Nov 14, 2022 | 03:20 PM
phatcivic's Avatar
Wouldn't that be the same I see in the catch can? And wouldn't oil come out? I've never in 20 years removed the oil cap from a running motor lol
Old Nov 15, 2022 | 06:49 AM
engifineer's Avatar
Not sure what you mean about "due for new valves" ? There is no replacement interval for valves and this is not something you normally replace unless something has happened to them. Do you mean valve adjustment? If they have never been adjusted and there are lots of miles on the car (especially the 06+ cars) then there is a chance valves could get burned causing issues, but normally you do not expect to just replace them at some interval.
Old Nov 18, 2022 | 06:37 PM
phatcivic's Avatar
I've always been told the AP1 valves need to be replaced and upgraded to AP2 valves at around 200k. I am at 200k. There are posts on here about it too.
Old Nov 19, 2022 | 02:11 AM
Slowcrash_101's Avatar
Those would be retainers but they only crack with mechanical over revs. Like previously stated burned valves and worn guides need replacing, but there is no timetable on that. Pistons rings start wearing and allow more oil consumption and blowby once they're worn. Again no timetable on that.
Old Nov 21, 2022 | 01:48 PM
yamaha6611's Avatar
pull your fuse pump fuse and crank it over, listen to the crank... when mine did this i had cylinder #1 go down to 150psi and you could hear the one cylinder very easy to crank over... it will do a
crank - crank- CRANK - crank - crank - crank- CRANK - crank kinda sound, the best way i can describe it lol
if you have that sound, you have a cylinder low for sure.
dlq04
Aug 4, 2014 03:26 PM
S1997
Aug 14, 2009 07:11 PM
jdmgpw04
May 3, 2006 07:46 PM
Jepu
22
Oct 28, 2005 07:33 PM
g-s2k
Oct 5, 2002 05:16 PM
