how bad is "dumping gear" on an ap2 differential
Originally Posted by turnerg1,Nov 21 2006, 02:18 PM
I guess I dont quite understand. I thought removing the CDV on the AP2 prevented the clutch from taking more of the damage because it engages quicker. Transfers torque to the rear diff quicker, etc.
Please correct me if I misunderstand.
Thanks,
T
Thanks,
T
Billman, I remember a thread a while back where a guy in your shop was swapping his ap2 flywheel for a toda flywheel and you said to stay tuned for his results, but they should be dramatic. I just recently swapped mine out for a toda as well. I'm wondering what your opinion was of the result?
When you're racing, which is what I'm assuming you're doing... (no other reason to really rev out the gears) you should be shifting so fast u dont need to even let off the gas. just use the clutch to change gears while remaining full throttle. it's the fastest way to shift if you can do it that way.
either way, ur diff and clutch wont hold up as long as it should if you beat on it like that... kinda common sense. it doesnt matter if it's ap1 or ap2.
The AP2 with the toda is doing great. Says it 200% improvement to the car, and his lap times have never been better. He did a whole write up on it, not sure where it is....he may have replied in Technical.
Found it...scroll down for Tel1sps's review on the Toda/AP2
https://www.s2ki.com/forums/index.php?showtopic=417350
Out of curiousity, is his setup noisy at all? Mine drives and grips great, but I have some noises. On hard redline shifts I hear an unexplained squeaking noise. No idea what it could be. I also have a rattling noise on some shifts and occasionally while accelerating almost sounds similiar to brake wear sensors. Is his setup noisy at all? I know that aftermarket flywheels sometims are noisy . . . its not bothersome at all I'm just curious as I want to know its not anything bad going on in there.
Originally Posted by Jsmply,Nov 21 2006, 03:34 PM
Thanks Bill, I actually have that same combo installed right now. I bought a stock clutch and ACT pressure plate and a local member was selling a Toda flywheel from a wrecked car with less than 1,000 miles on the flywheel so I grabbed it from him and put it in.
i would like to know about this one too.
i want to go with the ACT PPlate, comptech flywheel combo..
Originally Posted by asukadc,Nov 21 2006, 07:29 PM
thx for the input guys,
Of course change the bearings and clutch friction disc while you are in there! He will sell you everything you need and he is a honda dealer who knows about our cars and isn't just going to sell you something that will blow up your driveline.
Originally Posted by Billman250,Nov 21 2006, 07:48 PM
I've got 50k miles on my hardtopguy kit...love it.
