how bad is "dumping gear" on an ap2 differential
Old Nov 21, 2006 | 04:01 PM
  #21
asukadc's Avatar
yeah, i saw the hardtopguy's kit, does it include both bearings? (pilot bearings)
  #22
asukadc's Avatar
btw, how about act 's stage 1 disc? or stock disc still a better choice?
Old Nov 21, 2006 | 04:05 PM
  #23
Jsmply's Avatar
I believe it include's all bearings. E-mail or call him, Jeff is a great guy. I wouldn't go with an ACT disc, Jeff can tell you why. Its not neccesary, the stock clutch with ACT pressure plate has PLENTY of clamping force.
Old Nov 21, 2006 | 06:28 PM
  #24
RACER's Avatar
Originally Posted by SPRINGRATES,Nov 21 2006, 02:57 PM
you should be shifting so fast u dont need to even let off the gas. just use the clutch to change gears while remaining full throttle. it's the fastest way to shift....
Old Nov 21, 2006 | 07:05 PM
  #25
2point4gsx's Avatar
Originally Posted by Billman250,Nov 20 2006, 05:36 PM
AP2 dif is reportedly stronger, but marginally.
AP2 with delay removed: if you try to shift like lightning, you will certainly fry the clutch in no time. The heavy flywheel cannot slow in that quick of time.
AP2 cars take a different technique to drive, esp with the delay removed. If you've got it down, you will always walk an AP1, stock for stock. Timing is everything.
Bullsh*t, yO!
I walk my buddies new AP2 every time. I'll I have is an exhaust which reportedly loses HP. The spread of misinformation on this forum is contagious.
Old Nov 21, 2006 | 07:28 PM
  #26
asukadc's Avatar
Originally Posted by 2point4gsx,Nov 21 2006, 08:05 PM
Bullsh*t, yO!
cuz ur buddy dont know how to drive... honestly... throw both of ur car on the dyno and see what's up.
worse comes to the worse, he will walk u on 5th gear
Old Nov 21, 2006 | 07:43 PM
  #27
Jsmply's Avatar
Originally Posted by 2point4gsx,Nov 21 2006, 11:05 PM
Bullsh*t, yO!
Please read Billman's statement entirely before insulting one of the most respected mechanical minds on s2ki.
What he was saying was that the AP2 must be properly driven which is a different technique from an AP1. Your buddy probably doesn't drive it as well as he could.
jean-roch
Oct 22, 2012 08:15 AM
Stratocaster
Jun 15, 2010 01:05 PM
RL1924
Aug 28, 2009 05:32 AM
cloud_9
Mar 30, 2009 04:28 AM
S2KHardTop
Jul 20, 2006 03:36 PM
