How to change your coolant for dummies-
Old Mar 26, 2014 | 02:46 AM
  #21
flanders's Avatar
Just drain as much as you can using both drain plugs (radiator and block), it wont be much coolant left after that.
It is safe to mix them both though.
Old Mar 27, 2014 | 06:37 PM
  #22
darcyw's Avatar
Originally Posted by RoninS2k
Big thanks
my pleasure.
darcy
Old Mar 28, 2014 | 12:34 PM
  #23
Slowcrash_101's Avatar
Originally Posted by wankun
Thanks for the great write-up!
I have a question regarding switching over from Honda green coolant to the new blue coolant. I've read that all MY00 came with the Type I green coolant. To switch over to the blue stuff, how does one go about getting all the old coolant out?
Drain & fill with Type II coolant, run the car until the radiator fans kick in a few times, repeat the step 3-4 times?
OR
Drain & fill with distilled water, run the car until the radiator fans kick in a few times, repeat until radiator drains clear water, and then drain & fill with Type II coolant a couple more times to maintain the right 50/50 mixture?
I know these may sound overkill, but I want to be sure both types of coolant are not mixing. Any inputs would be appreciated.
You don't need to touch the block, just open the drain plug at the bottom of the radiator, and open the bleed bolt and radiator cap, once the fluid is slowly dripping out, close the bleed bolt, and the radiator cap, open the rear bleed which is the rubber nipple with a spring clamp on the line on the firewall in the middle. It's pretty obvious, then just blow compressed air in that hole and it will force more coolant out of the drain plug.
Old Dec 14, 2014 | 07:16 PM
  #24
mambo's Avatar
This writeup helped a lot! However, some things I experienced during my coolant change:
For whatever reason, I was unable to get the heater blowing hot with the engine just idling up to operating temp. I must have cycled the car on and off and bled the air out like, 8 times, the heat was still not blowing out hot air, and I wasn't getting much, if any, air out of the bleed valve, just coolant everywhere . I figured maybe the coolant isn't getting to the heater core so I revved the engine a bit (3k rpms for like 5 seconds) and boom! Heat started coming out of the vents! I shut off the car, opened the bleed valve and finally more air came out. I guess the air in there just needed a bit more pressure to get it out.
Old Dec 14, 2014 | 07:39 PM
  #25
darcyw's Avatar
Glad it helped.
Just remember not to open the bleed bolt while the car is running or torque it down much- like just barely snug with a 1/4" wrench.
darcy
Old Dec 15, 2014 | 05:44 AM
  #26
tupakbubba's Avatar
Another newbie question. On step two where you repeatedly squeeze the radiator hose, I understand from several people that after you squeeze some fluid out of the bleeder bolt, you close the bleeder then you unsqueeze. However, for the first few squeezes when no fluid is coming out, do you have to close the bolt before you unsqueeze? Thank you in advance!
Originally Posted by darcyw
Glad it helped.
darcy
Old Dec 15, 2014 | 07:30 AM
  #27
jkelley's Avatar
Yes, you need to still close it before you unsqueeze or all your's doing is pulling air back in and going nowhere.
Old Dec 15, 2014 | 03:22 PM
  #28
Question, I know it's not completely necessary, but since the 2nd bleed hole is the highest point in the cooling system. After doing this procedure wouldn't you also want to make sure coolant overflows from there when you squeeze the top radiator hose?
Old Apr 12, 2015 | 01:20 PM
  #29
videobored's Avatar
Just a word of thanks for the helpful write-up. I just successfully completed a radiator replacement and coolant flush on my AP1. These really are excellent cars.
Old Aug 29, 2015 | 07:59 AM
  #30
El S2000's Avatar
Just dropping by to say thanks. worked great and the pictures + Billman's writeup are fool proof.
