How do i remove the oil pan its half off!
Don't forget the AC Compressor bracket and the two on the bell housing.
Once you are sure you have them all take a flat head screw driver and start prying. The hondabond takes some leverage to break the seal.
Make sure you have a new bottle of hondabond to put it back on.
Just removed/replaced mine this weekend. Remove all the 10mm vertical bolts (there are 1 or 2 that are hidden), remove the two 14mm bolts connected to the tranny/bell housing, and remove the two 14mm bolts connected to the A/C compressor bracket (driver's side). Also don't forget the sway bar
Pry like mad once all the bolts are removed. Hondabond + dolly pin = mad prying.
Edit: Didn't see you mentioned the back is stuck; it's probably the dolly pin which is the rear passenger side corner of the pan. That was stuck for me as well.
