how do u know if you have overtightened valves?
Originally posted by mikecl713
what are the symptoms
well i told the mechanic to put the specs at 8 for intake and 10 for exhaust.
is it actually possible he could put that as .008 and .010 in MM? or is that impossible. or he could take it like i meant as in 8.0 and 10.0
im just worried if there was a confusion.
but my baby is more quiet and is more powerful
if your baby is more quiet and powerful then everything is fine. if they were adjusted too tight you'd hear a distinct tapping as the valve hit the valve seat, or if they were too loose you'd blow black smoke out the exhaust from incomplete combustion
Run as small a gap as you can, i dont know te expansion coefficients of your valves and burn temps so i cant figure it out, but as little as 10 thou can double the speed at which the tappet hits the stem tip.
[QUOTE]Originally posted by mikecl713
