how long (and $) to install F20C engine/tranny?
Old Nov 1, 2005 | 07:18 AM
Scot's Avatar
Default how long (and $) to install F20C engine/tranny?
I have an S2000 that has no engine or tranny in it. It did about 1 month ago, so the hoses / radiator, etc... are there.
If I buy a engine/tranny combo swap. How long would you expect it to take to drop it in and get everything hooked up?
i think there are just two motor mounts. can the swap come in from the top or do you have to undo the subframe and bring it from the bottom?
I was quoted $1k from one place. A more local place says $62.00 an hour and they won't commit to how many hours, but usually they are pretty good guys.
thank you.
Old Nov 1, 2005 | 08:23 AM
supertech's Avatar
I can do a full swap (given that all parts are on hand) in less than 8 hours. The best way to do it is to drop the front subframe and drop the whole engine/trans out of the bottom. I've seen it get pulled from the top but it's ugly. $1000 bucks to swap the motor seems like a good deal to me. Dealers will charge way more than that.
Old Nov 1, 2005 | 01:07 PM
Luder94's Avatar
Scot....give me a call tonight. It's completely possible to do it in your garage. Save yourself some $$$
Old Nov 2, 2005 | 05:16 AM
hondamanwill's Avatar
Complete Assembly Without Transfer of Parts B 8.8 Notes
Does Not Include: Transfer Of Any Part Of Engine Or Replacement Of Optional Equipment.
Complete Assembly With Transfer of Parts B 11.8 Notes
Includes: Transfer All Fuel & Electrical Units. Does Not Include Replacement Of Optional Equipment.
Short Block B 17.3 Notes
Includes: R&I Engine And Replacement Of All Necessary Components.
Long Block B 15.3 Notes
Includes: R&I Engine And Transfer All Necessary Components Not Supplied With Long Block.
Note
To R&R Cylinder Head, Add
Bare Assembly B 1.9 Notes
Complete Assembly B 0.6 Notes
To Grind Valves, Add
All Cyls B 3.8 Notes
Old Nov 2, 2005 | 06:08 AM
Scot's Avatar
was there supposed to be some times or some $ amounts with this?
[QUOTE=hondamanwill,Nov 2 2005, 09:16 AM]Complete Assembly Without Transfer of Parts B
Old Nov 2, 2005 | 06:18 AM
cdelena's Avatar
Originally Posted by Scot,Nov 2 2005, 09:08 AM
especially since my old engine and tranny is already out.
Sometimes it is slower if someone else did the disassembly.. connections and nuanced fitments can be less obvious.. especially if you have little experience with that particular car.
jrlandsman
Apr 1, 2010 11:47 AM
AusS2000
Apr 6, 2007 10:21 PM
KSR
Apr 1, 2006 06:32 AM
Tha_don_7
Nov 2, 2004 01:06 PM
spoolinmp3
Feb 8, 2004 07:26 AM
